Vray 5.2 gpu... Vram
  • #16
    All right let me do that Muhhamed
    Thanks
    i found driver GeForce Game ready 496.49 WHQL is that ok that option Muhhamed??
    • #17
      I installed that driver Muhhamed the newest and is the same, it doesnt render, only gives me a crash, i have been spending the whole morning just to render a scene... Everything fails for vray gpu, i'm tired about this, don't know what is happening
      • #18
        I did a test in a very simple scene it renders but takes a Lot of vram with this new update
        • #19
          Imposible to render a simple medium heavy scene, vray gpu light cache takes a Lot of vram, but a Lot, really a Lot
          • #20
            As a feedback vray gpu needs a very special attention!!! Im going to return to update 1, vray gpu light cache doesnt work at all!!! Please fix that problem, i was so happy with the news today, then tried it and then it doesnt work, i am going to install the update 2 but when this feature is ready, probably a hotfix or something but Right now i can't use it, only gives me a serius crash.
            Thanks
            • #21
              luisgamino2 If it crashes with BF/BF, then this is not about GPU LC or VRAM
              Could you please upload me one of your scenes?
              Muhammed Hamed
              V-Ray GPU product specialist
              chaos.com
              • #22
                I did a test with vray gpu bruteforce + bruteforce just with vray gpu, never with cpu i have a slow cpu i7 8700k, You can change from the ui to light cache to brute force
                Vray gpu doesnt work with update 2, takes too much vram Muhhamed
                • #23
                  Im ready to send You a scene... Vray gpu doesnt work Even with light scene... Very disappointed with this update!!! I'm going back to update 1, i'm going to keep the update 1 for months Konstantin this seems a very heavy problem... 10 test no single 1 render... I'm loosing just My time, and vray works SO Nice...but vray gpu is another thing
                  • #24
                    Hey luisgamino2
                    We are looking into this now, and we have a fix in place. would it be possible to have one of your scenes, so we make sure it is not a different issue on your side
                    Best,
                    Muhammed
                    Muhammed Hamed
                    chaos.com
                    • #25
                      Hi Muhhamed
                      I Can send You a scene, but how does it work, i have never sent a scene to chaos group support, is not going to take a Lot of time? Or can be tedius? The scene i'm going to send You always worked with update 1, but update 2 didnt work, is a medium scene not really heavy, but You can see there that something is not quite right.
                      Thanks
                      • #26
                        Dear luisgamino2,
                        The best way to share files with us is via our contact form.
                        When it is a scene related issue (as in this case), please choose 3D and rendering help under Request type and mention this thread in the description.
                        In addition, please use V-Ray > Pack Scene - a standard approach to collect all the included assets.
                        The discussion here will continue thereafter.
                        Regards,
                        Konstantin
                        • #27
                          One more thing that I want to note here:
                          We have identified an issue caused by the On-demand mipmapping option.
                          It can potentially cause the errors from one of the screenshots.
                          As a temporary workaround you can go back to Full-size textures.
                          Regards,
                          Konstantin
                          • #28
                            Hi guys,
                            There is a new stable build uploaded here - https://nightlies.chaosgroup.com/mai...table/20211112
                            One GPU memory issue has been addressed.
                            Everyone who has observed excessive VRam usage can give it a go and see if it's any better.
                            Thank you in advance,
                            Konstantin
