Question about Open GL in vray 5 for sketchup
  • Question about Open GL in vray 5 for sketchup
    Hi slavcho brusev
    i used to use sketchup with Open GL 4 or 8, then switched to Open GL 0 since i render with vray gpu ( to save more vram), right now i can increase again to 8 or 4 Open gl since i'm rendering with 16 bits.
    Open GL for sketchup does have an impact on the final render? For example a better antialiasing on the render
    Or it only affects sketchup??
    I see a better visuales on sketchup with Open GL with 4,8 or 16
    But how about when You render, does this have an impact on visuals or the perfomance, i think 4 is the standard, but if i have an extra vram if i increase to 16 in sketchup in Open GL, do You think i can achieve a better textures or better results in the final render of course
    Thanks in advance
    This setting affects only the SketchUp viewport. The Open GL setting will Not affect V-Ray in any way.
