Noise a and noise b ( 2uv vs 3d map)
  • Noise a and noise b ( 2uv vs 3d map)
    Hi Konstantin
    Yesterday López37 asked something really interesting.
    I was aware that both options offers the 3d map but almost forgot about that and yesterday i was playing with it.
    If i use noise a or noise b what is the difference using the 2uv vs 3d map... 2uv can be something similar to bump map kind of a ilusition kind of fake.?
    And the 3d map is kind of displacement with real effecs, more pronunced?
    And about the settings seems that if i use 3d map the parameters that should i use are under the options of the 3d map.
    Repeat x,y,z Offset x,y,z
    Rotation x,y,z
    This map is very important for a swiming pool or something kind of waves for the océan or in a Big piece of water.
    If i use 2uv option the parameters that are going to work are the normal parameters the clásical that offers the procedural textures.
    Please speak clear about this, vray is a Big software with so many options that sometimes we Even don't know how it works but when You Discover it, it works Nice.
    Thanks in advance
    * I'm using this procedural texture in the bump slot, using vray gpu 5.1
    Which one is better for a swiming pool, noise A or noise B??
    In noise A when do You use inflection??
    ​​​​​​Thanks
      There are so many options in both options, perlin, refractal.
      I believe this map is usufull too for frosted glass since this material has a really small bump.
      There are so many tools that a Lot of people don't have a clue how does it work.
