What is that folder?
  • What is that folder?
    What is this folder in :
    V-Ray for Sketchup/extension/library/materials
    It contains 499 JPEG files in 38 subfolders for a total of 70 MB.
    It seems to have been installed when V-Ray was first installed.
    What is it used for? Can it be deleted?​
    Windows 11 - RTX 3090 - AMD Ryzen 9 5950X - 128 Go RAM
    Sketchup PRO 25.0.634 + V-Ray 7.00.03
    3DS Max 2025.3 + V-Ray 7.00.08
    3DS Max 2026 + V-Ray 7.00.08
    Chaos Vantage 2.8
    GeForce Studio Ready Driver Version 572.16​
    Apologies for the very late reply!
    A while ago we updated the V-Ray material library assets to use 4K image files in .tx format instead of the earlier lower-res .jpg files.
    This change affected V-Ray for SketchUp/Rhino/Revit. Due to limitations in some of the host platforms, the old .jpg files were left as part of the V-Ray installation in order to provide lightweight alternatives for viewport representation instead of the more cumbersome .tx files.
    It allows V-Ray to offer increased quality of its built-in material assets while retaining the viewport performant.
    Altering or deleting any file located within C:\Program Files\Chaos Group (or /Applications/ChaosGroup on macOS) is highly discouraged.
    Kind regards,
    Peter
    Peter Chaushev
    Let's keep in touch
      Hi DCHA34 ​,
      I actually want to add something to what Peter said.
      One of the reasons for us to ship the jpg textures from the old library is out texture paths auto-resolution logic.
      When you open any scene in V-Ray we apply an advanced logic that resolves file paths:
      1) We first check if the stored texture file path is valid and if it is we use it.
      2) If not, we try to find the texture in the built-in library locations.
      That is where the jpgs come into play.
      The original old library was located in `V-Ray for Sketchup/extension/library/materials` and we decided to keep the textures there so that older scenes can still get auto-resolved in case the user has not packet the textures with the skp.
      3) Our lase resort, in case a texture is nowhere to be found in the library is to do a deep folders search relative to the .skp file
      We will consider stop shipping these files at one point.
      The issue that Peter described in his post has been addressed in a different way.
      We do use jpg files to show in the host app's viewport but they are now auto-generated.
      Hope that clarifies things to some extent,
      Konstantin
        Thanks for the detailed explanation.
        Chaos Vantage 2.8
