Vray gpu fur, what kind of textures should i use for thickness, lenght, gravity and bend
  • Vray gpu fur, what kind of textures should i use for thickness, lenght, gravity and bend
    Hi
    As the question is really clear what kind of textures should i use for the texture slot for the gravity, thickness, lenght and bend
    I want to go deeper with the vray fur.
    I havent see a single tutorial on how to use the vray fur in advanced way.
    Using maps for textures instead of the sliders.
    For vray gpu does it work?
    What kind of benefits should i see using textures?? and where do i get it??
    Thanks
    Another question, Can i use a two sided material for the material of the vray fur.
    All the time i use a hair material with vray fur, but i wonder how does it looks a carpet using a 2 sided material as a vray fur material.
    Does it gives nice results??
    Thanks
      Where is the cellular map in vray for sketchup? this map is usufull for texture the vray fur
      I did not find it
      Again what kind of maps do you use here???
      How do you use the curl in the vray fur???
      Thanks
        I found the cellular map
        How do you use it with the vray fur??? and what about the other textures like the noise,etc.???
        What kind of uses for this texture (cellular map) in other things?
        How do you use cellular maps in vray
        I had never use that texture in all my life
          Can we see a vray fur tutorial in a depth way please??
          Thanks
            I cant believe what is happening!!!
            the cellular map has a lot of options: plasma, cellular, dots, chips...
            Each one has diiferent effects with the vray fur...This tool can really do a lot of kind of tapestry but finally i found more options with vray fur, reading, investigating, watching videos in youtube...No single video from chaos group about this amazing tool and if there is a video about that is in the very basic level. Not for advanced users.
            Even if you change a bit those parameters the fur changes too.
            Also i found that the curl effect looks nice too if you dont increase too much the values.
            Again i cant believe it!!! What an amazing options do we have but we have to work hard and have patience in order to discover the complete posibilitys of the tools software.
            What other secrets does it has vray fur...using maps like the cellulars options are really really great.
            You know the software, you are how develop vray, why dont you gives us some presets with vray fur??? instead off spending hours and hours and hours achieving some kind of tapestry
            We dont have the hair and fur like in 3d max, but at least bring us the complete posibilitys with vray fur with sketchup
            It has a lot of options if you use textures for the maps like the noise or the cellular.
            Thanks
              In the variance layer of the vray fur there is 2 options for maps
              Bend direction map
              Initial direction map
              Im doing some experiments and i have to say mapping this 2 options gives the tapestry a complete new look
              Vray fur changes a lot when you map both options, im using cellular maps here.
              This is the first time i go deeper in vray fur...But i cant understand how does it works
              How does it works here the cellular maps???
                You can find more information about the Fur textures, and what they do in the V-Ray for 3ds Max documentation page on VRayFur
                You can try, but the fur renders optimally when the Hair material is used.
                I'll take note of this request.
                Sowing how grass or a carpet can be set up might be quite useful.
                This is true.
                These maps are exactly what my colleagues used for the docs examples here.
                I agree.
                I often times add those maps with some semi-random values for more interesting variety.
