Camera Matching with Vantage
  • Camera Matching with Vantage
    I posted this over on the Vantage forums but I thought I would post here as well.
    What's the best way to get my Vantage camera to match my SketchUp viewport exactly? I have run some quick testing with a file I have but even if I match the resolution, the field of view seems off. Is there a trick to get them to match exactly? Can Vantage pull the camera info from VRay for SketchUp since this matches SketchUp already?
    Matthew Valero, ASAI
    In my tests it seems that Vantage is matching the active SketchUp camera:
    What I did was:
    • ​Enable safe frame in SU
    • Export a vrscene
    • Load it in Vantage
    • Make sure that the aspect ratio that Vantage uses is the same (HD in my case)
    Can you describe your setup so that I can give it a try?
      Using live-link setup up a 2-pt camera in SketchUp that uses panning and zooming after turning 2-pt camera on. Vantage doesn't seem to recognize the pan and zooming done within SketchUp, which is something that a V-Ray camera can do within SketchUp. I would like exports from Vantage to match sketchy and hidden line views from SketchUp exactly. I asked the Vantage team in the forum and they said this is on their list of things to do at some point.
        Now, that is the reason.
        Currently, there is no such option in Vantage and hence matching your viewport would be impossible.
        I'll ask around and keep you posted on any progress made in that area.
        Konstantin
          Could the VRay camera in SketchUp communicate the settings to the Vantage Camera via the link link somehow? The Vray Camera inside of SketchUp has always done a wonderful job at matching the 2pt camera from SketchUp.
            It can and it does, but until Vantage starts supporting 2pp camera intricacies combined with panning and zooming there is nothing to be done.
            I'll speak to the Vantage team and let you know what they think.
              Awesome. I appreciate it!
