Hi, i couln't find on google search, while exporting plant factory trees, there is backlight maps in the maps folder, how can i use that map in Vray?
Backlight maps
I suspect the backlight is a Translucency map for the leaves. Brighter values should indicate that more of the light hitting the opposite side of the leaf is visible on the other side.
In V-Ray you can add a Translucency attribute to a material and attach it to the Translucency texture slot.
The Two-sided material can also be used for the same effect.
KonstantinLast edited by konstantin_chaos; 10-03-2025, 12:58 AM.
- Likes 1
Konstantin
