Backlight maps
  • Backlight maps
    Hi, i couln't find on google search, while exporting plant factory trees, there is backlight maps in the maps folder, how can i use that map in Vray?
    I suspect the backlight is a Translucency map for the leaves. Brighter values should indicate that more of the light hitting the opposite side of the leaf is visible on the other side.
    In V-Ray you can add a Translucency attribute to a material and attach it to the Translucency texture slot.
    The Two-sided material can also be used for the same effect.
    Konstantin
      Originally posted by konstantin_chaos View Post
      Konstantin
      Thank you..
