specular map
  • specular map
    I am going thru the process of making new materials, most of which I pull from arroway. A lot of these materials come with a specular/glossiness map. I was wondering where I would apply that in the vray mateditor to acheive the images they have shown on the arroway website. I know its probably a very basic question but I've never really gone thru the process of making many of my materials from scratch before.
    My process is this, I download the materials from arroway, import the diffuse map as a texture in the sketchup model and scale it correctly. Then I create a linked material, add the bump map, and scale it to get it looking right. I've tried putting the specular map in several different places but I can't seem to recreate the images on the arroway website. Any ideas on where this map should be loaded?
    Re: specular map
    well thru trial and error I've found that if I add a reflection to the material and then map the specular image from arroway into the "filter" component of the reflection properties in vray I can start to see some highlights. Not sure if this is the typical way to do it, but I am having some success doing it this way.
      Re: specular map
      The specular map would generally be put in a reflection layer's highlight glossiness map, or reflection glossiness map. But if you are happy with the results gained from placing it in the filter map then thats fine as well.
      Joe Bacigalupa
      Developer
      Chaos Group
