Rendering on Parallel Projection
  • Rendering on Parallel Projection
    has anybody tries rendering on a parallel project? e.g. Front view, Left etc... I'm not very sure how to resolve this problem 'cause every time I render on a parallel view it always comes out differently on the rendered version.. please help... does it involve with how the camera setting is adjusted ???
    F. U. B. A. R.
    Re: Rendering on Parallel Projection
    The best way to get those parallel views is to fake it by using a camera with a very long focal length (or very narrow field of view).
      So that means paralle views are not supported in vray? well I guess trying to adjust the camera focal length should do the trick, Thanks dalomar...
      F. U. B. A. R.
        With the physical camera no. With the standard camera, they do work. In my book, if you're using the physical camera, its easier to change a lens length/feild of view then the whole illumination of the scene
          So when you turn the Physical camera off, what do you set the default camera to?
          Standard? I can seem to find one that works. If I fake in SU with I can only get FOV to 1deg. That doesn't work. I want true elevations.
          update:
          OK, so I see that the rendering is there, what looked white has an image in it if I do heavy exposure adjustment of the rendering. Interestingly I see that I can slide the slider off the chart (beyond the Color Corrections box), and if I let go of the mouse I can't then reel it back in. Anyway to easily reset the color corrections?
