Applying materials in Vray for Sketchup...
  • Applying materials in Vray for Sketchup...
    Only just getting to grips with VRay, so I'm hoping this question is straightforward.
    I've built a model in Sketchup & am trying to apply VRay materials as explained in the manual... I right-click on a face, but don't get the 'VRay for Sketchup' option in the menu ... what am I doing wrong?
    Apologies again if this is a simple mistake
    Re: Applying materials in Vray for Sketchup...
    As far as I understand the latest version automatically puts any sketchup material applied to the vray material editor. The right_click method is gone. But as you can see from the screen shot I have 2 materials in sketchup but it does not translate to the vray material editor.
    Any one encountered this kind of a problem?
    Any help would be greatly appreciated.
    Thank you.
      I just tried the other way around......I created a vray material and it translated into a sketchup material..this way is working fine.
        Messed around with the program a bit more... managed to import VRay materials that were translated into the Sketchup Materials.
        Still a lot to learn I guess!
          how hard is it to convert vray materials into sketchup materials?
          thanks
            Hope this is what you mean...
            In the VRay Material Editor, right-click on Scene Materials & select Import New Material. Then navigate to any vismat files you've downloaded & they will appear as materials in your Sketchup Materials window.
              Excuse me, if I get you wrong...
              Vray materials show up in sketchups' own material window? How did you do it?
                The coming Service Release will do that.
                  Thank you.
                  i have the same problem
                  if you first set material in vray it ok but no to ideal why ? you cant adjust scale and position of material by sketchup ! you can do it if you first do material in sketchup but how then "export" it to window with vray settings material ? :/
