Shadow quality
  • Shadow quality
    I'm using Irradiance Map and Light Cache to create a render.
    But I'm having a problem related to the ceeling. I can't get better shadows than showed on the attached image. I have tried to play around with both Sample Size and Subdivisions
    What can I do to improve the quality ?
    Thanks
    Jorgensen
    Re: Shadow quality
    Well, what you're seeing is more related to IR than LC. There's a little loop hole in our default settings that put the adaptive amount at 1. This is usually not too bad, but when doing any sort of interior shots, this causes vast underplacement of IR samples. There are essentially very large gaps between some of the IR samples in the darker areas and thats where the artifacts are probably coming from. Changing the Adaptive Amount to .85 should help things quite a bit. After that you might have to bump up the hemispheric subdivisions a bit, but change the adaptive amount first.
      Re: Shadow quality
      Hi Damien
      Thanks for your input. I will try that later. I had to finish the image using Photoshop.
      VRay is a rather complex program, and has a lot of settings
      Jorgensen
        Re: Shadow quality
        Its very complex...however, once you begin to understand what each one is doing and how each one is working, it all starts to make a more complete picture. At a certain point the complexity melts away and you begin to see everything as a system instead of random setting here or random setting there.
          Re: Shadow quality
          Damian - great, I'll look forward to that that point!
          David
          Sketchup 2015
          Vray version 2.00
          www.davidcauldwell.co.uk
            Re: Shadow quality
            From the looks of some of your stuff David, I think you're a good ways down that path. Spot 3d will answer just about all of your questions, although you may have to read it over and over for a while ;D
              Re: Shadow quality
              Hi Damien
              Can you please explain where I find the adaptive amount and what IR means ?
              Thanks
              Jorgensen (noob :-[)
                Re: Shadow quality
                IR = Irradiance Map
                Adaptive Amount is in the DMC Sampler
