i cannot make shiny renders
  • i cannot make shiny renders
    i dont know what is the problem but i need your help guys here one of my sample its suppose to be shinny.I am sending my visopt file as well.
    http://img166.imageshack.us/img166/3282/12bp7.jpg
    here visot file
    http://www.2shared.com/file/3967630/...lc_medium.html
    pls i need help.....!!!
    www.jackscabana.co.uk
    Re: i cannot make shiny renders
    Two things
    1 make sure that the VISMAT material has a reflective layer
    2 a reflective surface needs something to reflect, so it may appear non reflective when there is nothing to reflect - in this case you need to add stuff, billboards etc.
    David
    Sketchup 2015
    Vray version 2.00
    www.davidcauldwell.co.uk
      aser28,
      David absolutely correct, i just want to add that you can also use an HDRI as you environment or put visible rectangle light in the scene witch will be reflected on the shiny material.
      www.Top3Dstudio.com
      SU 8
      VfS 1.48.89
      Win 7 64-bit
