Night render and moon shadows
  • Night render and moon shadows
    Hi
    I'm trying to create a simple night render.
    I have set the GI Skylight to ACOLOR dark blue, multiplier 5.
    And the background also to ACOLOR dark blue multiplier 1.
    It looks ok, but I would like some sharp moon shadows. Does anyone know how to achive that ?
    I'm I using a wrong method when I use ACOLOR ? could the same be done by using sky ? or do I have to use a V-Ray light ?
    Thanks
    Re: Night render and moon shadows
    anyone ?
      What version of V-Ray are you using? With the Service Release you should be able to not have a Sky map in the Enviroment slot but still get SU sun shadows if you tick Default Light in Global Switches.
      And have you tried setting the SU to a night time? Or reducing the multiplier of the SU sun?
        just quick guess. how abou using omni and play with the multiplier. i do beleive ( if im not mistaken) the sun is a omni light....so i guess the moon should be the same
        http://www.nomeradona.blogspot.com/
        http://www.sketchupvrayresources.blogspot.com/
        http://www.nomeradonaart.blogspot.com/
          Thanks to you both. I'll will experiment
