lost map location?
  • lost map location?
    I copied su file and texture files to other computer. All files are under one same folder.
    But when I opened the copied file, vray lost all the map file. It looks like vray does not recognize the texture file in the same folder automatically. So I need to select the map again for vray.
    Can anybody help me with this problem?
    Thank you in advance.
    moon
    Re: lost map location?
    You're saying that the folder is the same, but is the absolute path 100% the same? If its not, then V-Ray won't register it right out of the box. Once you add a search path, it will find those images. All a search path is is another folder that could contain information that V-Ray needs. To add a new search path, just go to one material and change the texture from what it was to its new location. After that V-Ray will find the rest of the maps.
      Ohh, that's a nice little trick.
