shadows
  • shadows
    hi everyone,
    i need some help about shadows, the render is working perfec but i have a problem with the color of the exterior shadows, they take a blue color and i want them in grey...what can i do???
    thanks
    Re: shadows
    Please post a screenshot using Photobucket or Imageshack. It's pretty much impossible to comment without a screenshot.
    SU 2018 + VfSU 4.0
      Re: shadows
      Your shadows are most likely a blue color becauese you are using a physical sky and sun. Try setting the environment to just a white color or an HDRI of something other than a sky. If you change your environment make sure you also change the background too.
      John Harvey<br />Intern Architect<br />Digital Design and Fabrication<br />http://jrharveyarchportfolio.blogspot.com/
        Re: shadows
        You can also try using the white balance in the camera options, and making it a blue color. This will make the shadows more of a white-orange color. Play around with this see what effects it renders.
        Justin
          Re: shadows
          You can adjust the Turbidity control of the sky itself to decrease the "blueish" appearance. Check the link below for examples
          http://www.spot3d.com/vray/help/150S...un_sky.htm#ex4
