Sketchup SetUP
  • Sketchup SetUP
    Ok, so when I make an animation I follow these steps. Is there anything I am missing?
    Change mode to Incremental Add to Current Map
    Clear your current map
    Set your map to be saved
    In Global Switches enable Don't Render Final Image
    Make sure Batch Render under Global Switches is enabled
    Check animation
    Re: Sketchup SetUP
    Dude you need to apply more things like Frame rate and stuff. Just kidding I have no Idea. Sorry. :-\ I know there other web sites to post your question though. Try That no one answers anything here. >
      Re: Sketchup SetUP
      ASGVIS is like the best web page in the world! I have a temper, and I use it!
      ::Note from Alrami= Come on man, we all get frustrated, be nice to the noobs, they grow up faster then you realize.
        Re: Sketchup SetUP
        what the heck ??? I log on to see if someone has answered my problem and I find you attacking me. P#$* off DUdeman!!! I'm just as confused as this guy!!!!!!!! >
          Re: Sketchup SetUP
          Yes, Sketchup Man, that was really uncalled for. That kind of response is nothing but trolling.
          Regarding the frame rate - if you use Distributed Rendering, then there's a bug you need to work around:
          Set VfSU FPS to 1
          Set the SU's transition time between frames to be total second * FPS (example, a three second transition between scenes at 25FPS would be 3 * 25 - giving you a 75s transition time in SU.
          If you don't use DR - then you can ignore that.
            Re: Sketchup SetUP
            LOL the internet is serious business.
            Sorry for the Hack Edit Dudeman, you had it coming. Although I appreciate your sentiment, we are not always here and that can be frustrating when you need an answer, no point in everyone getting all angry about it though.
            ThomThom is not only right but awesome. BTW has anyone played around with PDplayer? I have only had a few mins to use it but I already love it.
              Re: Sketchup SetUP
              Bam! Octahack! ;D
              PDplayer - oooooooh! shiny!
                Re: Sketchup SetUP
                booooh pricey!
                But might be worth it...
                  Re: Sketchup SetUP
                  Hello, I'm new. : this blog is so cool. RIGHT ;D
