Depth of Field
  • Depth of Field
    So I've been searching around for more information on depth of field. I've seen the manual and have played with the test scene. I am able to achieve DOF with the default camera on easily. The aperture setting adjusts the blurriness effectively.
    When I select the physical camera, the aperture setting becomes "un-selectable". The aperture field becomes grayed out. If this is the setting that adjusts the blurriness, does the DOF not work with the physical camera on?
    I've seen this post:
    http://asgvis.com/index.php?option=c...sg9672#msg9672
    Here, the physical camera is on, and the DOF aperture is still adjustable. Is this a function of SketchUp vs. Rhino or Max? Is this not available on SketchUp just yet?
    Any information would be helpful.
    Regards,
    Justin
    Re: Depth of Field
    Oh, and I am running V-RAY version 01.05.30 with SketchUp 7.1.6087.
    Thanks!
      Re: Depth of Field
      So I think I've answered my own question. I've been lowering and raising my F-number......lower creates more blurriness, higher creates less. It's just not the same as what is displayed in the manual.
        Re: Depth of Field
        It works!
          Re: Depth of Field
          thats a beautiful image, quite realistic.
            Re: Depth of Field
            Awesome render!
            Have a terrific day!
            _KN
            Personal projects (Fantasy and Sci-Fi): http://www.chaosgroup.com/forums/vbu...ASY+SCI-FI+ART
              Re: Depth of Field
              I prefer doing the DoF with the VFB Channel`s Z-Depth, and then doing it in the Photoshop, it`s better to control there than at the V-Ray`s Camera DoF attribute.
              Matheus de Paula Bueno<br /><br />Architect and Urbanist<br />MSc Student in Architecture at Brasilia University (UnB)<br />Brasília - DF - Brazil<br /><br />Personal Portfolio available at:<br />http://portfoliompb.blogspot.com
                Re: Depth of Field
                ... not to mention the VFB Z-Depth/PS Lens blur method takes about 1/20th of the time compared to waiting for V-Ray to render DoF.
                SU 2018 + VfSU 4.0
                  Re: Depth of Field
                  is it as realistic? Where I can I find a tutorial on this method?
                    Re: Depth of Field
                    While changing the F-Number does affect the blurriness somewhat, it drastically changes the brightness of the render. I've tried adjusting the ISO Value and Shutter Speed to compensate, but with little success.
                    What did you do compensate for the change in brightness after you've changed the F-Number?
                    I am currently using V-Ray 1.49.01.
                    SketchUp 8.0.11752
                    Windows 7 Professional-64 bit
                    Intel(R) Core(TM) i5 K655 @ 3.20GHz
                    8.00GB of RAM, 1.2TB Hard Drive
                    Marcus McLin, Intern - Serena Sturm Architects
                      Re: Depth of Field
                      ISO and Shutter speed. How much did you change the F-Stop by, and how much did you adjust ISO or Shutter Speed to compensate?
                        Re: Depth of Field
                        Aces High,
                        There's an excellent Z-Depth/Photoshop DoF tutorial at the following link:
                        http://www.onnovanbraam.com/index.ph...epth_of_field/
                        Just ignore all the 3DSMax stuff at the start and jump straight to the bit where you see the grayscale Z-Depth image. The guy ywho made the tut uses a slightly different method to create teh depth map; he creates a self-illuminating material, but for most purposes you can just use the standard V-Ray Z-Depth channel image instead.
                        The method isn't perfect, it often needs some manual blurring (which is described in the above tut), but the whole process usually takes a fraction of the time compared with rendering out "true" DoF in V-Ray.
                        Jackson
                        SU 2018 + VfSU 4.0
                          Re: Depth of Field
                          thank you
                          MACbook PRO 2.5 GHz Intel Core i7, 16GB RAM, OSX 10.9.5, WACOM Intuos 5 Touch, Sketchup 2016, vray_adv_20026494_sketchup_2016_osx_x64.dmg
                            Re: Depth of Field
                            Yea, the Z-depth is new to me. I've played with it a bit and have had great success. I will no longer be playing with the depth of field within V-ray. Thanks for the heads up!
                            Cheers,
                            Justin
