Specularity Map
  • Specularity Map
    I've seen this question asked in many posts on this forum, but none are ever answered.
    I've got a few textures from Arroway Textures that come with specularity maps. In Vray, there are places to insert maps for diffuse, transparency, bump, displacement, reflectivity, and refraction, but nothing for specularity.
    Where in Vray do I insert the specularity map?
    I am currently using V-Ray 1.49.01.
    SketchUp 8.0.11752
    Windows 7 Professional-64 bit
    Intel(R) Core(TM) i5 K655 @ 3.20GHz
    8.00GB of RAM, 1.2TB Hard Drive
    Marcus McLin, Intern - Serena Sturm Architects
    Re: Specularity Map
    and what is an specular map also please ;D
    los campeones no nacen, se hacen...
      Re: Specularity Map
      I would put that in a second reflection layer...
        Re: Specularity Map
        That was my first impression, too. But what if the texture only has a specularity map, but no reflectivity map?
        SketchUp 8.0.11752
          Re: Specularity Map
          I second that question.
          In the previous VfS version specular map assigned under reflection> frensel's white color "m" > selecting bitmap type> and choosing your Spec. map.
          But with the new version I'm not sure it's still the place for it...
          www.Top3Dstudio.com
          SU 8
          VfS 1.48.89
          Win 7 64-bit
            Re: Specularity Map
            Same thing - use the TexFresnel map - but now it's named perpendicular and parallel. Old VfSU'd white color slot is the perpendicular one.
              Re: Specularity Map
              [/quote]
              When you say "fresnel's white color," do you mean we have to change the fresnel color to white? Because by default, the fresnel color is gray.
              SketchUp 8.0.11752
                Re: Specularity Map
                No - the white is just the amount of reflection. And if you use a map then the colour won't matter.
                And to me the defaults are white Perpendicular and black Parallel.
                  Re: Specularity Map
                  Gotcha.
                  Thanks for clearing that up for me, ThomThom.
                  SketchUp 8.0.11752
                    Re: Specularity Map
                    We change the names because now is easier to understand the concept. I made this small explanation about the fresnel effect.
                    Best
                      Re: Specularity Map
                      Awesome explanation, Fernando!
                      SketchUp 8.0.11752
                        Re: Specularity Map
                        Very good explanation!
                        I have a question, the specular map should go to both slots (perpendicular and parallel) ?
                        If you want some reflection while looking at it parallel, then yes. It all depends on the properties of the material. As Fernando mentioned, if you don't want any reflecction parallel, then leave it black.
                        www.Top3Dstudio.com
                        SU 8
                        VfS 1.48.89
                        Win 7 64-bit
                          Re: Specularity Map
                          Is not necessary to use the specular map on the parallel slot. The reason is because the parallel slot already have a black color (matte).
                          Best
                            Re: Specularity Map
                              Re: Specularity Map
                              very nice explantion. how about falloff map do you have the same illustration?
                              http://www.nomeradona.blogspot.com/
                              http://www.sketchupvrayresources.blogspot.com/
                              http://www.nomeradonaart.blogspot.com/
