a "diffuse" coloured shadow problem
  • a "diffuse" coloured shadow problem
    I am doing some interior-test with the new V-ray in Sketchup (7.0).
    I am using 2 basic-colours materials straight from sketchup (red and white).
    What I don't like because I can't uderstand is how to controll the "diffusing colour" of the shadow.
    The shadow-colour of the cube on the plane. I don't know if it is the right word..but please look at the image for a better comprehension.
    Why is it red?
    Is it a material problem?
    or something in the rendering setting?
    (I am using gi_irmap with no physical camera)
    thank you
    Serrag
    Re: a "diffuse" coloured shadow problem
    maybe it settings of reflection is too high?? try to reduce the ior reflection?
      there is no reflection layer.
      the materials are straight from sketchup....
        It's the color that bounces of the saturated surface. Go to Indirect Illumination and lower the Saturation value till you satisfied with the result.
        Note: this affects all GI saturation.
        www.Top3Dstudio.com
        SU 8
        VfS 1.48.89
        Win 7 64-bit
          YES!
          thank you very much!
          I'm just wondering.... is there any value closer to the real-world light?
            Well in the real world, if you had a white room with a red box in it, and light hit the box, the walls would appear red due to the reflected light from the red box. So actually you're trying to be less realistic.
            Devin Kendig
            Developer
            Chaos Group
              midn you - are your colour values, 100% red and 100% white?
                dkendig: I understand what you mean...but I think that the reflected light is too much in some-circumstances... and why I can not controll the single-reflected-light-material..... ?
                thomthom: yes, but I will make some more test tmrw
                thx for the support.
                  try without using the full intensity of the RGB channels.
                    My "real" problem is on an iterior room.
                    I have done a simple versione of the problem here.
                    I can't believe that in "reality"
                    in a room with a red floor, if the wall are white-matt (226, 226, 226),
                    I can see a "pink" ceiling due to the red (255,0,0) floor....
                    but with saturation 0,
                    it looks....almost ok.
                    any other suggestion?
                    thx!
                      As I said before, you should lower the saturation till it looks good enough. Setting the value to 0 is not a good GI solution.
                      www.Top3Dstudio.com
                      SU 8
                      VfS 1.48.89
                      Win 7 64-bit
                        Have you tried without full intensity on the RGB channels yet?
                          thomthom, Yes it is little bit better but the red is getting too dark..
                            How much did you reduce by?
                            The thing is that 255 can often cause problems as it's at the far end of the scale. So usually try to reduce by a little amount.
                            • #15
                              untill 190 same problem.... but it is already getting too dark...
