a "diffuse" coloured shadow problem
  • #16
    Re: a "diffuse" coloured shadow problem
    have you tried rendering with an less intense material - saving the IR solution, then restoring your colour and using your stored IR solution?
    • #17
      Change the color of the floor to light gray and make a render and save the irradiance map solution. The in the Irr Map select "from file" and load the saved solution. Change the color for the floor to red again and make the render.
      Best
      • #18
        It looks good!
        thx
        • #19
          Is there a way to set it as for V-Ray for 3ds Max?
          http://www.spot3d.com/vray/help/150S...idemtl.htm#ex3
          THX!
          • #20
            no, sorry. We haven't set up our override material to work like that, and we don't have an option that allows you to specify another type of material other than a default layered material.
            Devin Kendig
            Developer
            Chaos Group
            • #21
              ok thx!,
              is there any "similar set" that I could do using the layered material for to obtain the same effect?
              the solution from fpedrogo is fine
              but
              it takes too much time to reder the same image 2 times...
              • #22
                unfortunately you cannot control any properties of the override material, other than the diffuse color.
                Devin Kendig
                Developer
                Chaos Group
