I have an i7 chip in my comp wit hWindows & as the OS in case this matters.
When I run a render with the irradiance map as the primary engine, Dmc as the second it takes about 10hrs t orender an 800x600 image, if I use the preffered DMC primary, light cache secondary it doesn't even build the light cache and instead offers this error message:
Beginning render sequence
Preparing renderer...
Preparing scene for rendering.
[RenderView] startCameraTime=0.000000, endCameraTime=0.033333
[RenderView] numCameraTMs=2, numFrames=1, frameSamples=2
Initializing built-in VFB.
Preparing camera sampler.
Preparing scene for frame.
MtlMulti (noname) "mtls" parameter is deprecated; use "mtls_list" and "ids_list" instead.
Compiling geometry.
Preparing ray server.
Creating and initializing 8 thread(s).
Allocating memory for build data of 815182 faces (22825096 bytes, 21.8 MB).
Initializing face build data.
Creating 'done' event.
Starting first thread.
Waiting for thread completion.
Releasing thread resources.
Preparing faces for intersection tests.
SDTree statistics:
Total number of faces stored: 815182
Max tree depth: 40
Average tree depth: 24.4608
Number of tree nodes: 157757
Number of tree faces: 2008787
Number of tree leafs: 67067
Average faces/leaf: 29.9519
Memory usage: 49.59 MB
Scene bounding box is [-264.545,-438.469,-4.09034]-[136.059,389.878,194.213]
Preparing direct light manager.
Preparing global light manager.
Irradiance sample size is 84 bytes
Photon size is 56 bytes.
Light cache sample size is 120 bytes.
Building light cache.
Tracing 4000000 image samples for light cache in 8 passes.
Setting up 8 thread(s)
Light cache time interval is (0.000000, 0.000000)
Bitmap file "C:\ProgramData\ASGvis\VRayForSketchUp\Textures\Wo od_Lumber_ButtJoined.jpg" loaded.
Bitmap file "C:\HDRImages\Studio_HDR_giveaway_by_zbyg\studio00 4preview.jpg" loaded.
Bitmap file "C:\Documents and Settings\All Users\Application Data\ASGvis\Materials\Textures\Brushed Metal.png" loaded.
Bitmap file "\\DESIGN5\In BOX\KEITH\Textures\Tiles 50x50mm Dark Grey Dark Grey Grout 6x6.jpg" loaded.
Bitmap file "C:\HDRImages\Studio_HDR_giveaway_by_zbyg\studio00 4.hdr" loaded.
I don't know what to do to make it render. If I open a basic SketchUp file and just click render then it works fine. Help!
Compiling geometry.
SDTree statistics:
Max tree depth: 40
