hi people...
i come here with another question... :P
in the past version of vray for sketchup, when i wanted to render a photomatched sceene, i used to set an output size that was exactly the same of the matched photo( for example, if the original photo's size is 1000 x 500, i used to set that same size in the output), that way, after i rendered, i used to go to photoshop and there was no need to scale (and therefore distort) the render... it just used to fit exactly on the background image...
yesterday i rendered a sceene, and i set the output to the exact size of the original photo, but when i have the final render, eventhough the size is the one i set, proportion is different and i had to scale...
is there a way to just set some output, and get a final render that matches exactly with the original background photos?...
let's say for example that i just want to make a photomatch of a window... i import the photo that i want to use for the photomatch, i adjust the photomatch, and then i just render with the same output size of the original photo... in the past version (that was really cool), the pure render of the window used to fit exactly on the original photo...
please, let me know if i am being clear or not
and thank you in advance for your time ;D
