subdivision question
  • subdivision question
    can anyone tell me how they set up materials with low glossyness n still prevent noise from affecting the materials, its very hard to achieve
    Re: subdivision question
    Even if you've set a high subd. value for the material the final result depends on the "Image Sampler" subdivision settings.
    See more ifo at spot3d.com http://www.spot3d.com/vray/help/150S...agesampler.htm
    www.Top3Dstudio.com
    SU 8
    VfS 1.48.89
    Win 7 64-bit
      but what i have learnt from vray is that different materials react differently, if i increase subdivisions am increasing render times, which i always try to avoid, but with the material setting for a particular material is there no other way to control the reflectivity n shine n not require a high subdivision?
        My man, you can't have your cake and eat it too.
        If you want a good quality
        Good quality = higher settings = longer render times.
        That's why most people use low settings for testing and high settings for final render.
        www.Top3Dstudio.com
        SU 8
        VfS 1.48.89
        Win 7 64-bit
          lol, i know that, so ur saying there is no way around this
            You can find settings that work for you time wise and quality wise. So you'll get decent quality in reasonable time.
            www.Top3Dstudio.com
            SU 8
            VfS 1.48.89
            Win 7 64-bit
