How can i make this material
  • How can i make this material
    Hello
    Do some one know`s what`s the best way the make this material? look here http://www.baunetzwissen.de/objektar...layout=galerie
    Thanks for your help
    Re: How can i make this material
    Do you know if it is...
    -Stucco
    -concrete
    Wait...what material am i looking at? The glass or the exterior masonry finish?
    More info we know the better
    -gallystops-
    -Intel Core i7-930-<br />-12GB DDR3 SDRAM-<br />-ATI Radeon HD5970-<br />-1TB Hard Drive-
      It`s a stucco, the exterior masonry finish, that is the material i want?
      Thanks
        Bolite,
        you'd need to make a displacement map in photoshop.
        Draw some random lines and play with layer effects such as Inner/Outer Glow or Relief.
        White areas will pull surface normals and therefore make the material stick out, whereas black areas won't alter the object geometry.
        Make sure to check the direction of the surface normals.
        Don't forget to post your results, mate!
        Cheers,
        Matt
