Comping VFB Layers
  • Comping VFB Layers
    I am trying to comp a render using the various channels saved out from VFB. I have read a dozen tutorials on this method using MAX, but when I try to comp my layers out from VfSU, it does not get me to what my RGB pass looks like. I have attached a graphic from another site that I used as a reference. Is there a color mapping setting or VFB setting I need to use to get this to work?
    Matthew Valero, ASAI
    Hi Matthew!
    I do not understand your question, can you be more specific, please?
    the RGB pass it is usually what we understand/see as final render, the others can be modified in the "VFB Channels" configurations.
    Intel(R) Core(TM) i7 975 Extreme Edit. 3.33GHz / 6.4GT/s 8Mb box / Motherboard Gigabyte GA-EX58-UDS / Asus GForce GTX275HDMI 896DD3 (12Gb) / Windows 7- 64bit / Sketchup 2013 / V-Ray
      There is a method where you take your diffuse pass and along with the GI, Lighting, Reflection, Specular, and Self Illumination passes, can combine them together in Photoshop layering so you get the same exact result as the RGB pass. The reason why you would do this is total 100% flexibility to edit the passes and have more power in finalizing your final image. If you go to 4:00 on this video, you will see what I mean. http://www.youtube.com/watch?v=30Sf22jgJbQ
        I followed the Comp A method in the video with a test and this is what I get. The comp does not match the RGB pass at all. Maybe this method will not work with V4SU. This is what I am wondering.
Name:	Test Comp A.jpg
ID:	846372Click image for larger version
          humm, ok! about the "RGB pass", i unaware completely!
          Thanks a lot Valero
            I'm not totally sure if I am doing this correctly. Maybe it only works using LWF and EXR exports. I will give that a try also.
