Perhaps a silly question but how do you create a new colour and say apply a slight reflection. I can't see anything suitable in the presets. The tutorials on materials for 3.4 doesnt seem to cover this basic task.
Create a new simple colour
Perhaps I am misunderstanding your question, but what you might be looking for is simply changing the value of the Reflect parameter. See https://docs.chaosgroup.com/display/...RDF-Reflection for more info.
Kind regards,
PeterPeter Chaushev
Let's keep in touch
Keep in mind that when adding additional layers their order matters - top-most layer in the material settings is rendered as the outer-most.
There is also a difference in the render results between adding an additional reflective layer and using the VRayBRDF's Reflection parameters.
Kind regards,
PeterPeter Chaushev
Let's keep in touch
Originally posted by grain View PostPerhaps a silly question but how do you create a new colour and say apply a slight reflection. I can't see anything suitable in the presets. The tutorials on materials for 3.4 doesnt seem to cover this basic task.
The easiest way to do that is:
> Create a 'Generic' material
> Choose a color in the 'Diffuse' slot
> Set the 'Reflect' color to something bright (close to white)
> Make sure that 'Use Fresnel' is enabled (it is by default)
That's all. If a blurrier reflections are needed:
> Set the 'Reflection Glossiness' value to something smaller than 1.0 like 0.8 for example. It isn't recommend to go lower than 0.5 with the glossiness.
There are a couple of library materials that will also work. One example is the following:
> Plastic_Simple_Shiny_Gray > Create it and change the 'Diffuse' color to your liking
Hope that helps.
Regards,
Konstantin
