Alert Popup window
  • Alert Popup window
    Would it be possible to have an alert window when opening a Sketchup file in the following cases:
    - missing texture files
    - missing .vrmesh or .vrscene files​
    Thank you.
    Windows 11 - RTX 3090 - AMD Ryzen 9 5950X - 128 Go RAM
    Sketchup PRO 25.0.634 + V-Ray 7.10
    3DS Max 2025.3 + V-Ray 7.00.08
    3DS Max 2026 + V-Ray 7.00.08
    Chaos Vantage 2.8
    GeForce Studio Ready Driver Version 572.16​
    Hi DCHA34​,
    Both are more or less the same and we can certainly detect missing files and react to it.
    However I have some concerns:
    1. When a .skp is loaded, V-Ray is not automatically activated. We can only show an alert when you first interact with V-Ray...
    2. ​Some files are replaced by the SU bitmap buffers in case they are missing. Should we alert in this case?
    3. Checking file paths can be very slow if a network location is in play. This is not something we can optimize, it's on the OS (Windows / macOS) side. Are you willing to wait for the check to complete?
    4. A way for this behavior to be disabled should be implemented.
    Konstantin
      ​Some files are replaced by the SU bitmap buffers in case they are missing. Should we alert in this case?​
      Indeed, I think it would be great.
      Chaos Vantage 2.8
