Edit multiple lights / Lights inside componants that work.
  • Edit multiple lights / Lights inside componants that work.
    hi. not sure if it's just me but..
    i cannot find a way to edit more than one light at a time. this is incredibly annoying if you have many lights and are experimenting.
    also, say i make a spotlight cone with an omni light in then want to make it a componant to copy the same light around a room (the light wont emmit anymore from inside the componant).
    could you put lights into a group or layer and give the same perameters?
    thanks
    stu
    Re: Edit multiple lights / Lights inside componants that work.
    has anyone else experienced this?
    i see lighting as the most important thing.
      i would like this too... hopefully the vray lights not rendering in the components issue would be rectified in the service release...
      i would like to see a global "lights" window.. where u could choose the lights (any kind of lights.. be it rectangular or omni) and tweak it from there....
      ...SU6 Pro...VFSU...KT...<br />// Intel Q6600 Core2Quad 2.4Ghz // 3Gb Ram // Geforce 8800 GTX //
        Let all the light component use the same light material, then if you edit the material, all the lights changes.
