VrayScene from Maya? (and compatibility questions)
  • VrayScene from Maya? (and compatibility questions)
    Hello,
    I could get a VrayScene from 3dsMax working.
    (it imports everything in single pieces, but it works)
    I did also a test with an human eye as a vrscene from Maya.
    This did not work. The same scene loaded into 3dsMax worked.
    - Is there a limitation in UE4 for Maya vrscenes?
    - Which else are the general known limitations: are all kinds of materials like VrayfastSSS, Blendmaterial compatible in vray UE4?
    - Do I have to bake all input maps also for vrayScenes? (texture compositing nodes, ramps etc. when imported as vrscene)
    Thanks
    Hi BeneZ
    As a general workflow for the moment we recommend to bake complex inputs and have simple materials where possible of course. You can check here in the docs about the supported features:Supported Features. If the shading graph of the material is complex or has procedural textures(noise, fresnel, color corrections, composites, etc.) they will be skipped on import.
    Alexander
    Alexander Atanasov
    V-Ray for Unreal & Chaos Vantage QA
    Chaos
      Thanks,
      so I will test from Maya again.
      Is there a way from 3dsMax to bake higher maps than 2k (the 2k baking was shown in your tutorial)?
