Material Override?
  • Material Override?
    I am wondering, if I would like to replicate the Vray Material Override, for the Reflection of the Environment.
    Is this possible within Unreal?
    And if so, how would the nodes look like?
    I am talking about this wonderful option, where you can change the reflection map of your material.
    And it will consider the hdri or map you plugged into that slot.
    I haven't been able to re-produce this within Unreal.
    Thanks for any little help,
    appreciate it!
    www.bernhardrieder.com
    rieder.bernhard@gmail.com
    Hi bernhard,
    You want to reproduce this with UE materials with or without V-Ray? With V-Ray you can try using the VRaySettingsEnvironment override. However, that cannot be set per material, it's globally applied and doesn't work well when there is a skylight in the scene currently. i am not aware if you can replace the reflection from inside UE materials and if this is possible at all. There is a way to add a cubetexture and mix it with other inputs inside the material(https://drive.google.com/uc?id=1do53...We-5tH1lDGyHIl) and make it look like there is another reflection but not override the true reflection.
    Alexander
    Alexander Atanasov
    V-Ray for Unreal & Chaos Vantage QA
    Chaos
      Thank you Alexander, that kinda makes sense. Yes, I wanted to reproduce without Vray Materials. After importing a datasmith scene, and re-creating materials.
