Hi, we just updated to the new Vray Next, in our daily workflow we use Vray and Phoenix Fd, but when we try to render using the GPU we have this 2 situations:
- Phoenix FD Ocean Texture seems to be not compatible, is still like this?
- Guessing that Phoenix Ocean Texture doesn't work, we simulate a sequence using PhoenixFD Liquid container with really low parameters and small size, because we only need the ocean environment and we need to render really fast during the weekend, that's the reason of using GPU, the problem is that if we render one frame it works, but when we want to render a sequence it renders only one frame and then stops, if I render a single box this doesn’t happens, but when PhoenixFD goes into the equation it does.
- Any recomendations about the GPU + PhoenixFD workflow? I only need the ocean surface, no need of any interaction.
Thanks in advance.
Thanks in advance.
