Second 1080TI
  • #91
    Here is a screenshot
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    • #92
      Hey Bobby, plug your new gpus and let me know how it goes man!
      I'm curious to see how that DELL PSU will do on them, airflow as well!
      Regards,
      Ledian
      • #93
        I have a large exterior with everything in it. My shared GPU is 64GB and my dedicated is 11GB. I have no clue what the difference is. This isn't the kind of scene I would use GPU on, unless I could. When I open my typical interior I'll see what that read.
        Have a look at MSI Afterburner.
        Will help you monitor your GPUs way better than TM (you can customize your fans, voltage, clocks etc)!
        Regards,
        Ledian
        • #94
          I sure will. They should arrive the first of next month.
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
          • #95
            thanks for the screenshot. graph shows ~60% of vram used. my 5GB guess was pretty close.
            Marcin Piotrowski
            youtube
            CGI OCIO config 04
            • #96
              Originally posted by piotrus3333 View Post
              win10 on a work machine right now takes only 470MB of vram (gpu-z)
              Ya, GPU-Z will show 400 MB used, but for GPU rendering you can only access 9 GB out of 11 on a 1080Ti
              This is old news btw, this is been the case since 2015
              http://bfy.tw/MOg9
              After filling your 9 GB on a 1080Ti, you will get an error"Cannot allocate enough memory"
              This happens with any renderer, not just Vray and with other cards..
              Are you using Nvidia GPUs at all?
              If so, clone any geometry with Vray GPU on your cards, and take a screenshot of GPU-z showing more than 9 GB used..
              About the 5 GB, this is for a project that is taking 64 GB of RAM.. so what do you expect?
              Muhammed Hamed
              V-Ray GPU product specialist
              chaos.com
              • #97
                This exterior screen grab wasn't using GPU. It's showing 3%-11% used and 100% CPU. When I open my interior GPU scene I'll grab another screenshot.
                Bobby Parker
                phone: 2188206812
                • Ryzen 9 5900x CPU
                • ​Windows 11 Pro
                • #98
                  Yeah obviously, I do use Max and Vray GPU myself
                  Max will not take up 5 GB of VRAM for GPU scenes..
                  and like I said, you can render with standalone and close Max if you want
                  Muhammed Hamed
                  chaos.com
                  • #99
                    glorybound Don't use task manager for monitoring VRAM..
                    Muhammed Hamed
                    chaos.com
                    • What should I use? I just downloaded MSI afterburner?
                      Bobby Parker
                      phone: 2188206812
                      • Ryzen 9 5900x CPU
                      • ​Windows 11 Pro
                      • I just rendered a 6K mammoth exterior with Forest Pro, Railcone, Walls & Tiles, DOF, and motion blur. I rendered it in a little over an hour on CPU. I want these speeds on my interiors, which is why I am going down the GPU path. My interiors were taking 4+ hours per still. On some recent interiors I was getting 4 hours on CPU, so I tried Hybrid for the first time and I got 1 hour times. Honestly, I was expecting a ton of errors, but everything worked great except my Walls & Tiles materials, which I just swapped out. With my second 1080ti I am hoping for 1/2 hour interior render times.
                        Bobby Parker
                        phone: 2188206812
                        • Ryzen 9 5900x CPU
                        • ​Windows 11 Pro
                        • Hopefully you can get your render times to like 30 minutes when you install the 2 new GPUs, this is really why many people have been investing in GPU rendering recently
                          And what is really cool about Vray is that you can still use your 2 CPUs in rendering.. Should be a massive speed boost really with bucket mode
                          At office we have 7x 1080tis in one render machine, any scene takes less than 15 minutes in 4k Res.. and I'm really happy with where Vray GPU stands now
                          If something is missing make sure to make a thread and see the Devs input!
                          btw, do you spend much time on the IPR? or do you use it at all?
                          the GPU IPR is quite fast and you can use Optix denoiser for lighting and shading.. this workflow has been very nice as I tend to spend time tweaking things.
                          Muhammed Hamed
                          chaos.com
                          • Yes, I use IPR all the time when setting up my scenes. I couldn't imagine going back to pre-IPR.
                            Bobby Parker
                            phone: 2188206812
                            • Ryzen 9 5900x CPU
                            • ​Windows 11 Pro
                            • Originally posted by glorybound View Post
                              GPU-Z for monitoring VRAM works best
                              AFter burner is good to keep an eye on temps, fan speeds..etc
                              Muhammed Hamed
                              chaos.com
                                Will this guy power my 43" 4K monitor in 3DS MAX? No external power and one slot.
                                https://www.amazon.com/ZOTAC-GeForce...shatblog198-20
                                Why do you want to use an external card for your monitor?
                                Use Display port on one of your 1080tis.. if I understand what you mean correctly
                                The card you use for monitor, is what is being used for viewport performance, you don't want a 1030 for 3Ds Max viewport..
                                Muhammed Hamed
                                chaos.com
