GPU and textures
  • GPU and textures
    Extensively testing GPU version and kind of stuck here. I have buncj of tiled mipmapped .tx files. Feels like I don't have an option like in CPU version to:
    - use max texture lod
    - use tiled mipmapped textures, only force resize or on-demand (it takes ages to start and I don't feel it takes into account heavy DOF in scene, I know that sounds strange, but it would be great )
    Any ideas ?
    I just can't seem to trust myself
    So what chance does that leave, for anyone else?
    CG Artist
    What 3d platform are you using?
    What is the exact version of V-Ray that you are using?
    Could you share your scene as an example so we could take a look?
    Setting the "Texture Mode" to "Full size textures" should load all your textures with their original size.
    Nikolay Kusht | chaos.com
    Team Lead, 3D Support | contact us
      Scene - I think no. I was too specific and loooots of textures (I was converting from rs to vr and since rs is caching all its textures to own cache - rstexbin - they are always mipmapped). It was 3dsmax, vray next.
      But, the q was - why there's no such options, and that't it. Maybe when it should arrive at gpu version.
      CG Artist
        Sorry, I am not sure which option that is missing for V-Ray Next GPU you are referring to.
        Currently, you could determine the resolution and size of textures to optimize the memory usage by changing the Textures Mode(||Render Setup window|| > Performance tab > Textures rollout). For more information check the online documentation:
        https://docs.chaosgroup.com/display/...X/GPU+Textures
        If you are referring to something else, please give us more details.
          Oh, I forgot. It was maya.
          Global Max Mipmap Resolution
          CG Artist
