GPU Light Cache Preview
  • GPU Light Cache Preview
    Doesn't the light cache create a preview like in bucket mode?
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    The show calc. phase is checked and grayed out. I don't see the calc. phase when I render.
    Bobby Parker
    phone: 2188206812
    • Ryzen 9 5900x CPU
    • ​Windows 11 Pro
      It does when you are rendering locally. DR on the other hand uses out-of-process rendering which doesn't show the LC calculation.
      Peter Matanov
      Chaos
        Good to know... why?
        Bobby Parker
        phone: 2188206812
        • Ryzen 9 5900x CPU
        • ​Windows 11 Pro
          It's not working because of some internal technical reasons. It will be fixed someday.
          Peter Matanov
          Chaos
            It is a huge inconvenience. Isn't it pretty high on the list of bugs to be fixed?
            Bobby Parker
            phone: 2188206812
            • Ryzen 9 5900x CPU
            • ​Windows 11 Pro
              I guess I can start it without DR, let the LC calc and then turn DR back on.
              Bobby Parker
              phone: 2188206812
              • Ryzen 9 5900x CPU
              • ​Windows 11 Pro
                No. We switched it off long time ago and barely no one complained since then.
                Peter Matanov
                Chaos
                  Makes me wonder how many people are using it then. It provides a quick preview that I usually stop, tweak, and hit render again. This can happen dozens of times before I let the render proceed.
                  Bobby Parker
                  phone: 2188206812
                  • Ryzen 9 5900x CPU
                  • ​Windows 11 Pro
                    Will see what can be done about it. What are your DR settings?
                      Bobby Parker
                      phone: 2188206812
                      • Ryzen 9 5900x CPU
                      • ​Windows 11 Pro
                        Ok, thanks. Yeah, will see what can be done about the preview.
                          I also lose my effectResults. It just turns black, so I don't see it until the end.
                          Bobby Parker
                          phone: 2188206812
                          • Ryzen 9 5900x CPU
                          • ​Windows 11 Pro
