recommended nvidea driver
  • recommended nvidea driver
    which is the recommended nvidea driver to use?, for no problem with gpu....
    Recommended NVIDIA driver for V-Ray GPU is version 436.30
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
      Doe's it mean that this driver is ok for older V-Ray versions too? I ask this because VfR isn't released so often and I afraid diver and V-Ray version needs to match or not?
        Hmmm... IDK. On the top of the Chaos GPU page has the recommended driver listed.
        Bobby Parker
        phone: 2188206812
        • Ryzen 9 5900x CPU
        • ​Windows 11 Pro
          Right, but doe's this driver works for any V-Ray version? One plugin version is released day 1 an other day 10 and the next day 40. During this time the recommended driver number is changing. Doe's all V-Ray version works with the latest recommended driver or doe's driver and V-Ray version need each other?
            Should be valid for all latest V-Ray versions per product. If you experience problems with the suggested driver, please report.
            Peter Matanov
            Chaos
              Unfortunately, Nvidia driver 436.30 does not work for Nvidia AI denoising. Please see attached Vray progress window snapshot. Also tried the latest Nvidia driver version 441.12 without success. Tried all older drivers upto 421.02. Nvidia AI works on none.
              Currently using Vray Next for Rhino 5 4.10.01, release Sep 24 2019
              Windows 7 64-bit.
              Nvidia Quadro K4200
              The graphics card is detected in the Asset editor.
              Please help!
              B. Maio
                b.maio_SGA Here at Rhino 6 / Win10 / driver 436.30 / GTXx080ti the denoiser works. Maybe the card is the problem.
                  Doubt its a hardware problem. Its CUDA supported. Worked fine for me in the earlier Vray for Rhino update 1 version.
                  B Maio
                    Hello,
                    Unfortunately this is a hardware requirement of the newer NVidia AI Denoiser - it requires Maxwell or newer GPU architectures. (https://docs.chaosgroup.com/display/...noisingEngines)
                    Yavor
                    Yavor Rubenov
                    V-Ray for 3ds Max developer
                      Originally posted by yavor.rubenov View Post
                      Hello,
                      Yavor
                      Hi Yavor,
                      Thanks for the notification. I guess my card just got obsolete for the new Vray. Very disappointed. I guess, I can do without the new Denoiser for now.
                      Good day
                      B. Maio
                        The V-Ray denoiser is still compatible.
                        Yavor Rubenov
