which is the recommended nvidea driver to use?, for no problem with gpu....
Recommended NVIDIA driver for V-Ray GPU is version 436.30Bobby Parker
www.bobby-parker.com
e-mail: info@bobby-parker.com
phone: 2188206812
- 128gb Vengeance RGB Pro RAM
- NVIDIA GeForce RTX 4090
- ​Windows 11 Pro
Doe's it mean that this driver is ok for older V-Ray versions too? I ask this because VfR isn't released so often and I afraid diver and V-Ray version needs to match or not?www.simulacrum.de ... visualization for designer and architects
Hmmm... IDK. On the top of the Chaos GPU page has the recommended driver listed.Bobby Parker
phone: 2188206812
- ​Windows 11 Pro
Right, but doe's this driver works for any V-Ray version? One plugin version is released day 1 an other day 10 and the next day 40. During this time the recommended driver number is changing. Doe's all V-Ray version works with the latest recommended driver or doe's driver and V-Ray version need each other?www.simulacrum.de ... visualization for designer and architects
Unfortunately, Nvidia driver 436.30 does not work for Nvidia AI denoising. Please see attached Vray progress window snapshot. Also tried the latest Nvidia driver version 441.12 without success. Tried all older drivers upto 421.02. Nvidia AI works on none.
Currently using Vray Next for Rhino 5 4.10.01, release Sep 24 2019
Windows 7 64-bit.
Nvidia Quadro K4200
The graphics card is detected in the Asset editor.
Please help!
B. Maio1 Photo
b.maio_SGA Here at Rhino 6 / Win10 / driver 436.30 / GTXx080ti the denoiser works. Maybe the card is the problem.www.simulacrum.de ... visualization for designer and architects
Originally posted by Micha View Postb.maio_SGA Here at Rhino 6 / Win10 / driver 436.30 / GTXx080ti the denoiser works. Maybe the card is the problem.
B Maio
Unfortunately this is a hardware requirement of the newer NVidia AI Denoiser - it requires Maxwell or newer GPU architectures. (https://docs.chaosgroup.com/display/...noisingEngines)
YavorYavor Rubenov
V-Ray for 3ds Max developer
Yavor
Thanks for the notification. I guess my card just got obsolete for the new Vray. Very disappointed. I guess, I can do without the new Denoiser for now.
Good day
B. Maio
