RTX Support for GPUS?
    around 4min
    https://linktr.ee/cg_oglu
    Ryzen 5950, Geforce 3060, 128GB ram
      Originally posted by oglu View Post
      I like waht i see here.
      17min on my 8core 16 thread i7
      3min on my 2080ti in RTX mode
      Oww damn! Huge difference, I wonder how does it compare to 2990wx. Btw did you have to update your V-Ray or simply updating nvidia driver did the trick?
      My Artstation
      Whether it is an advantageous position or a disadvantageous one, the opposite state should be always present to your mind. -
      Sun Tsu
        Ive been working with Vray Next GPU for a bit now and here are my results with the RTX - My system is an i9 14 core OC to 4.5ghz - Titan RTX and a 1080ti -
        With Hybrid Rendering on GPU, for a decently complex scene, I was rendering it at 2 min and 48 seconds. When I switch it to RTX and pure GPU, it rendered it in 2 min and 58 seconds.. So a 10 second difference. This is still killer because even though its slower, the CPU added would usually decrease render times by a much larger margin. I now need to test CUDA GPU only vs RTX GPU only.
          You have to install the latest nightly build.
            Is the CPU render running with V-Ray Adv or is it running in CUDA (Hybrid) mode?
            • #21
              Non Hybrid mode here.
              • #22
                Thanks, I hope the one for Maya is already available.
                My Artstation
                Sun Tsu
                • #23
                  Sweet, thanks for responding! Would it perhaps be possible to see a screenshot of the scene?
                  • #24
                    Sorry this project is under NDA.
                    • #25
                      Gotcha. Thanks for the replies!
