Originally posted by glorybound
View Post
Nvidia 30 series cards
Yes, the uploading scene does become an issue and sometimes sends me back to CPU. I think that is a Forest Pro issue.Bobby Parker
www.bobby-parker.com
e-mail: info@bobby-parker.com
phone: 2188206812
- 128gb Vengeance RGB Pro RAM
- NVIDIA GeForce RTX 4090 X2
- Windows 11 Pro
Originally posted by ^Lele^ View PostWe'd rather not do this, the reasons are explained as well as i could muster above (none of which include fear of misrepresentation. It's a *scientific method* issue.)
You, however, are free to do as you please: If it floats your boat, go places with it!
Just please do not make it into a sweeping statement: "A is faster than B" has been proven too simplistic a claim to hold any value, time and time again.
It's not going to change in the foreseeable future: context, and math brought to bear within that context, have unavoidable weight, and are proven to sway results greatly.
- Likes 2
Originally posted by francomanko View Post
But I just think it would be useful to have comparisons of gpu and cpu from other users , no point me testing stuff after ive bought it.
Ive used GPU for the last 5 almost exclusively. I added a second GTX 1080ti and run hybrid mode with my TR 1950x. It is for sure faster than my CPU alone, but its not without its issues. Maya projections, 2d file texture stagger, camera auto exposure....a lot of these things you can find workarounds for, but you have to go digging and find the weird way it needs to work...like having to go and render in CPU mode first for auto exposure to work, then switch back to GPU. I think spent a couple of hours trying to copy camera settings during production time on a shot before I worked that one out.
With progressive, denoiser, DOF and motion blur, it can spit out a clean car interior render animation frames at 2500px in about 7 mins. That's seriously fast for average hardware, in CUDA mode, and apart from some very small niggles, it was production quality.
One point I think I'd like clarifying, is the comparison between GPU RAM and system RAM. I read somewhere that 10GB on a GPU equates to about 64GB system RAM. That the numbers arent interchangeable. For example, saying a displacement eats up 40gb system RAM so how would it ever fit on my 1080ti?
- Likes 1
Originally posted by Neilg View PostBBB3 uses GPU exclusively and hits that quality bar - however his scenes are designed from scratch on gpu and they're very self contained projects. Lots of displacement and detail, so it's possible, but still not a great 1:1 comparison of what the workflow is like.
https://www.flickr.com/photos/bbb3viz/with/48973807192/
Scene size hasn't been a huge problem for me. Some of my scenes are pretty big (this one, or this one), and they fit on my 20GB of VRAM with a ton of space to spare. You just need a little bit of discipline in prepping the scene and you can use on-demand texture mip-mapping, which can save you gigabytes of VRAM. Clearly it won't fit every workflow or work with gigantic scenes. But we also have to admit that Archviz artists have never been trained to optimize for RAM consumption. We're pretty wasteful in how we build our assets. If you start thinking more like a game artist, for instance using normal maps to take mid-res assets to the next level of detail or decimating heavy assets judiciously, you can go a long way.
One thing I wouldn't recommend is switching back an forth between the CPU and GPU version. Scenes made for one will tend not to work in the other. And of course, every time you switch, V-Ray wipes out all your render settings.Check my blog
- Likes 1
I've had some weird issues with the on demand mip mapping, for the most part it seems fine but certain textures were messed up, i will have to have a better look to see what was causing it, but it made me wonder, I know you can specify vray to resize the textures as well, but it would be pretty useful if you could specify texture sizes based on sets, object ids etc. Similar to unity and unreal where you have control on a texture by texture basis, that way you could easily specify fore/mid/background geo and different texture sizes. Might be a useful extra tool in the belt
Originally posted by francomanko View PostI've had some weird issues with the on demand mip mapping,
Thanks for your input, BBB3 . Can you quickly explain why "there's no going back" for you? What makes it a better solution than CPU for you?Aleksandar Mitov
www.renarvisuals.com
office@renarvisuals.com
AMD Ryzen 9 9950X 16-core
96GB DDR5
Speed of iterations mainly. And the way my rig is set up, CPU rendering is orders of magnitude slower. I don’t have a farm so for me, it’s either using the GPU to render in minutes or letting renders cook overnight, which I haven’t done in years. And also, all my assets and scenes are now set up for the GPU so that’s kind of an investment.Check my blog
- Likes 1
Originally posted by seandunderdale View Post
My point exactly.
Morning all,
I'm fairly new to Vray so I'm still getting my head around the different elements of the computer which are utilised for different elements of the whole export. I have used task manager to monitor my current computer, but this computer is very basic, and difficult to match to a modern day 3D machine / 3000 series.
Primarily I'm interested in how much CPU you require if you utilise CUDA or RTX only.
I'm currently try to get a spec together for a very basic 3D machine for my IT guy to build. Budget is perhaps in the £1 - 1.5k region... I guess the main question is, with one 3000 gpu, how low can you go for CPU?
At present I'm thinking:- GPU = RTX 3080 (only 1 due to lack of multi gpu support and budget)
- Motherboard = MSI x570-A Pro
- CPU = 3600 or 3700x
- Ram = 16gig of x brand (semi decent)
With the above in mind, what I like about CUDA / RTX is that your computer can still be used once rendering. When utilising CPU only, I pretty much cant use my workstation, so I find the CUDA / RTX more practical from that point of view.
In terms of usage, I will be exporting high quality stills of relativity simple models, with the aim of creating animations down the line. Examples of my types of work as follows:
Once again, ideally I want CUDA or RTX to be doing the hard work so that I can render in the background whilst doing minor tasks, such as emails and the likes of.... but the question is, how low can you go with the CPU?
Thoughts welcome.
Best
Theo
Originally posted by john_gulland View PostAt present I'm thinking:- GPU = RTX 3080 (only 1 due to lack of multi gpu support and budget)
The 3080 is $700 alone... it's a really tough build to put together for that price.
The price scales really well from 3600 to the 3900x - it's double the price for almost double the performance, ish. That's a really incredible level of scaling and 1.7x the cpu power for $200 is a missed opportunity.
16gb of ram is really not enough these days... you'll run out if you have chrome open while rendering. 64gb would be a minimum.
A 3900 based cpu build with 64gb ram and no graphics card will set you back $1200. that + a 3080 would be around $1900 and get you a an all rounder that can do cpu and gpu rendering with enough ram to work in photoshop in the background and not micromanage background processes. Your build is only $300 less but means you'll be running out of ram constantly and cant fall back on cpu rendering in a pinch.Last edited by Neilg; 14-09-2020, 04:57 PM.
If I can find a GPU box, with enough room for two of these new cards (GEFORCE RTX3090) (with vlink), all connected with a SCSI card, I would buy today. I am not sure why these are not all over the place, but I can't find what I am looking for.Bobby Parker
phone: 2188206812
- Windows 11 Pro
- Likes 1
The same as power as the Titan RTX, but cheaper?
https://www.nvidia.com/en-us/geforce...ries/rtx-3090/Bobby Parker
phone: 2188206812
- Windows 11 Pro
Benchmarks are looking good!
https://techgage.com/article/nvidia-...g-performance/https://linktr.ee/cg_oglu
Ryzen 5950, Geforce 3060, 128GB ram
