V-Ray Material Issue
  • V-Ray Material Issue
    I'm new to V-Ray and what I'd like to do is to increase the color of my custom leather material. I used a generic material and loaded a brown leather image and its corresponding bump image. The material looks bland and dark. In 3DS Max I increased the "Output Amount" on the same texture and was able to brighten up the dark texture without having to use a bright light to increase the color. Any help would be greatly appreciated. I would assume that there's an equivalent parameter that is comparable to the Output Amount in 3DS Max.
    So what exactly is the problem? It seems that you already figured it out yourself. I would do exactly as you did if my lighting was correct but the texture was darker than I would like it to be.
    Aleksandar Mitov
    www.renarvisuals.com
    office@renarvisuals.com
    AMD Ryzen 9 9950X 16-core
    96GB DDR5
      Use the 'Output amount' in the plugged texture itself (available both in the Bitmap and VRayBitmap node)?
        I'm not seeing what you are describing. Attached is what I can see on the bitmap parameter window.
          Ok. I just looked and found what is comparable to the "Output Setting" in 3DS Max. I tried it and it works equally as effective. I found the setting under V-Ray's Bitmap setting under the "Color Space" dropdown. The name of the parameter is called "Custom Gamma Curve" I would assume this is what you were referring to? Anyway, this is exactly what I was looking for and it works like a charm.
          BTW, another V-ray technician rep[lied to me via email and suggested wrapping your texture in a Simple Mix texture. The "Multiply Result" value is the same as "Output amount".
          For fine-tuning the texture output, you can instead use the Color Correction or Spline and Bezier Curve textures.
          I haven't tried that yet but will experiment with that recommendation just to compare the results.
          ​​​​​​​I'm really starting to enjoy V-Ray compared to my 2016 version of Mental Ray.
          ​​​​​​​Thanks for all the help to the V-Ray team, much appreciated.
