How to set up Vray GPU
  • How to set up Vray GPU
    I cannot find V-Ray GPU in the ActiveShade list, how can I set up V-Ray GPU?
    Jackie Teh
    3ds Max 2023, V-Ray 7 Hotfix 2 [7.00.08 build 00000]
    Do you mean that you want it as a viewport? If so, then you can choose that from the viewport itself, when you click on e.g. 'standard' it'll show various viewport IPR options.
      I did but nothing happens, i mean the GPU not running
      Jackie Teh
        Is your card listed in the Perf tab like here?
        Does it work in cpu mode?
          Yes it is in the list.
          I can run IPR in V-Ray 5 mode, but cannot run in V-Ray 5 GPU
          Jackie Teh
            It doesn't work at all....not even a regular frame buffer version?
            If not then that is really weird and I'm afraid I'd have no idea why that is.
            Hopefully someone else can pinpoint why this happens.
              Thank you for your help!
              I really hope someone could help and guide me
              Jackie Teh
                Are you trying to run Vray realtime in a viewport? Or are you trying to run it in the Frames buffer? If it's the frame buffer, you need to press the button shown below;
                  I have no problem to run it in frame buffer, just nothing happen when i try to run it in realtime viewport, still trying here...
                  Jackie Teh
                    Do you get any messages in the V-Ray log when you start Viewport IPR with V-Ray GPU ?
                    Yavor
                    Yavor Rubenov
                    V-Ray for 3ds Max developer
                      Originally posted by yavor.rubenov View Post
                      Yavor
                      Forgot this post, The GPU works fine now...it just needs some time to start for the first time, I guess...
                      Jackie Teh
                        Ahh maybe you had the kernels compiling - it only happens on the first run and it takes more than 30 seconds.
                        Yavor Rubenov
                          Noted with thanks
                          Jackie Teh
