How do I control which light materials work in the vray volume fog?
Well if you insist on it, disabling DI should suffice. Otherwise, you can use the VRayInstancer to instance Mesh Lights to a tyFlow particle system (you need to enable the Particle Interface in the Interfaces tab of the tyFlow node) and afterward disable the "Affect Atmosphere" of the VRayMeshLight.
