Which textures mode to use when using .tx textures?
  • Which textures mode to use when using .tx textures?
    I have a scene where most of the textures are .tx format. Which textures mode should I use in this case - full, on-demand mip-mapped or resize?
    Aleksandar Mitov
    www.renarvisuals.com
    office@renarvisuals.com
    AMD Ryzen 9 9950X 16-core
    96GB DDR5
    The .tx image format is a container of tiled bitmaps with different resolutions, designed for mipmapping. It would certainly help with a project's VRAM optimization. However, this does not restrict you from utilizing the other texture modes - it's a question of optimization vs. quality.
      Thanks for the reply. So if I use Full mode, would I benefit from the memory conservation properties of .tx textures or will Vray always use the highest resolution mipmaps? Should I use mip-mapped mode if all my textures are .tx and would my texture quality suffer in any way? Which mode is best for IPR rendering if I want fastest time to first pixel and which is best for final rendering where I want both highest quality and memory conservation?
      Aleksandar Mitov
      96GB DDR5
        No, V-Ray will use the full resolution image.
        Mipmapping works by using lower resolution images for objects that are far away in the background (there really isn't a point in loading a full-resolution texture for objects, the details of which are not visible anyway).
        Mipmapping is the most optimal.
          Awesome, thanks!
          Aleksandar Mitov
          96GB DDR5
