Texture Blur
  • Texture Blur
    Is there a way to globally change texture blur? I found a script, but it doesn't seem to do anything.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    As far as I know, you can't change texture blur with the GPU engine currently. This only works with the CPU engine. https://forums.chaos.com/forum/v-ray...p-texture-blur
    Aleksandar Mitov
    www.renarvisuals.com
    office@renarvisuals.com
    AMD Ryzen 9 9950X 16-core
    96GB DDR5
      Okay, so the error is the filtering type. I'll see if I can change that globally. Thank you!
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        I can't find a way. When I send to the Chaos Cloud, I get errors about blur. However, I have no way to change that on all my textures. I guess I'll learn to ignore the error .
        Bobby Parker
        phone: 2188206812
        • Ryzen 9 5900x CPU
        • ​Windows 11 Pro
          I've been using the script below to globally change the blur value of all textures in the scene. Try it out. I hope it helps!
          Code:
          for m in getclassinstances vrayhdri do m.coords.blur = 1.0
          Aleksandar Mitov
          96GB DDR5
            Perfect, thank you! it worked.
            Bobby Parker
            phone: 2188206812
            • Ryzen 9 5900x CPU
            • ​Windows 11 Pro
              Good to hear!
              Aleksandar Mitov
              96GB DDR5
                I will see if we can do something about the errors, I believe they don't affect V-Ray GPU in any way. Like what Alex said, this blur control doesn't work on GPU
                Best,
                Muhammed
                Muhammed Hamed
                V-Ray GPU product specialist
                chaos.com
                  It seems to be Forest Pro stuff that has the blur issues.
                  Bobby Parker
                  phone: 2188206812
                  • Ryzen 9 5900x CPU
                  • ​Windows 11 Pro
