Chaos Scatter Stopped working
  • Chaos Scatter Stopped working
    Hello
    I have a few chaos scatters , I can see them in the viewport but none of them render anymore. They render in CPU , does GPU not support Chaos Scatter?
    Using max 2024 and Vray 6.2
    Thanks
    So the help says its supported,
    I have reinstalled and also tried it in a simple test scene but nothing is rendering for me.
      Hi dubsyman_sousand
      Indeed, Chaos Scatter is supported on VRayGPU - sorry to hear you are facing issues.
      Can you recall if Scatter worked on GPU in the past or this is the first time you are actually trying to run a GPU render with Scatter? I also have a few other questions:
      1. Do you receive any errors in the render log when when starting the GPU render? If so, can you copy-paste them here?
      2. Have you ever had Chaos Corona installed on this machine?
      3. Are there any other user profiles on this machine? Any special characters (non-latin) in the username?
      4. Can you try to uninstall V-Ray + Scatter again and make sure any leftover files are removed:
      C:\Program Files\Chaos Group\Scatter\3ds Max 20xx;
      C:\Program Files\Chaos Group\V-Ray\3ds Max 20xx;
      C:\ProgramData\Autodesk\ApplicationPlugins\VRay3ds Max20xx;
      C:\Users\<username>\AppData\Local\ChaosGroup\V-Ray for 3ds Max 20xx
      any Chaos Scatter leftovers from old installs in C:\Program Files\Autodesk\3ds Max 20xx\Plugins,
      then run the V-Ray 6 installer again?​
      Nikoleta Garkova | chaos.com
        Hi
        Yes it did work in the past, I had all these trees and bushes setup in it.
        I only have this warning in the log
        ] Warning : EdgesTex/RoundedCorners is not supported through procedural texture
        • ​Corona is installed but in trial mode I was using it to convert some textures.
        • The latest change I did was I installed vray for houdini.
        • I dont have any special character profiles.
        • will try clean reinstall .
        Thanks
          Hi, thanks for posting. Please try to uninstall your Chaos Scatter from Windows program files and after that reinstall V-Ray. There is a similar issue discussed here.
          Vladimir Krastev | chaos.com
            After reinstall is working, Thanks
