3ds Max, GPU, nvidia denoiser
  • 3ds Max, GPU, nvidia denoiser
    hello. i'm finding that the nvidia denoiser is smoothing out some walls that i have which have a stipple pattern as a very low bump. it's a black and white bitmap in the bump slot of a vray material. i'm using vray 6.x. i haven't really rendered this level of detail before, so i'm noticing it just now. below is the "done" and below that is while it's rendering. my noise limit is 0.001, progressive, samples limit 5000. any thoughts on how to preserve some of these details? rendered image size is 2560x1440 (perhaps too small?). thanks!
    Try the intel denoiser.
    https://linktr.ee/cg_oglu
    Ryzen 5950, Geforce 3060, 128GB ram
      This is typical of the Nvidia denoiser, it doesn't work well in this case. Some people still use it for production rendering although I suggest using it with IPR
      As Oglu suggested, the Intel denoiser should work better, we updated it in V-Ray 7 with more features/stability
      Best,
      Muhammed
      Muhammed Hamed
      V-Ray GPU product specialist
      chaos.com
        thank you kind sirs, that did the trick! i'll need to tone it down
        Click image for larger version  Name:	image.png Views:	0 Size:	1.24 MB ID:	1228457
