VRay RT for Animations
  • VRay RT for Animations
    We have a big animation coming up and was wondering whether anyone has used RT successfully for the preview aspect of animations with moving objects ?
    I should probably do a bit more research on this but, can RT render over a network ?
    www.morphic.tv
    www.niallcochrane.co.uk
    It can render via DR but not backburner, as far as I know. I used to make previews with fprime. They were grainy as hell but blew any viewport preview out of the water in terms of motion and lighting evaluation. Combine that with a properly rendered every 10th (or so) frame and you have yourself a good preview
    But to answer your question, I don't know how you achieve this in VRayRT.
      I think a "time" feature is going to be added to VRayRT in the near future to make animations possible (dont quote me on that though )
      Chris Jackson
      Shiftmedia
      www.shiftmedia.sydney
        It is possible to set something like this manually through a MaxScript that waits for a while, writes the ActiveShade output and then advances the time slider.
          Is this script available now?
            Vlado, do you have a sample script to do this?
              Nope; I don't have a script ready - I just know people that have done it.
              We will definitely include something like that for the next update though.
                Those how had done that script, if you have a heart, could you please share those scripts, would be wonderful
                3LP Team
                  Re script for animation....?
                  Is it available for use please?
                  Help would be appreciated.
                  Thank you
                  phil
                    Here is the script that I used; you will probably want to modify it for your needs:
                    Code:
                    rollout test "RT Animation" (
                    timer clock "rtClock" interval:5000 --tick once every 5 seconds
                    local cframe=animationRange.start
                    label Frame "---"
                    on clock tick do (
                    b=vrayGetRTBitmap()
                    b.filename="c:/temp/test" + (formattedPrint ((cframe as integer)/160) format:"04i") + ".png"
                    save b
                    cframe = cframe+1f
                    Frame.text = cframe as string
                    if (cframe>animationRange.end) then DestroyDialog test
                    sliderTime=cframe
                    fn rtAnimation=(
                    sliderTime=animationRange.start
                    createDialog test
                      Thank you , but I am thick, so..........
                      I have copies the script into a new script file, saved it to my Script in the root autodesk folder.
                      Under scripts in the rt dropdown, I have tried it in both pre and post render, and nothing appears in the folder I created on my C drive under temp and test.
                      I have run the short animation I have and don't see anything appearing ?
                      I presume i will have to compile the .png files in another programme or max video post, when I get it to work.
                      Can you tell me what i am doing wrong please.
                      If this works it will be great, thank you again.
                      phil
                        Just paste this into a new script; press Ctrl+E to evaluate it, start the V-Ray RT render and wait until it has loaded the scene and is rendering; then open the MaxScript listener and type
                        Code:
                        rtAnimation()
                        This will cycle through your animation and wait for 5 seconds for each frame (the 5000 number in the script) and will create .png files in the c:\temp folder. You can reassemble these files either with a compositing application, 3ds Max Video Post, or simply the 3ds Max RAM Player.
                          Thank you again.
                          It would not work untill I removed the space between the RT Animation on the top line of the Main script.
                          It works very well, thank you very much.
                          many thanks, and from the one of the people who programme the software, it is an excellent service.
                          phil
                            Hi Vlado,
                            Thanks for posting that script. I was trying to test it out but I get an error on this line
                            b=vrayGetRTBitmap()
                            I have tried the script with a windowed activeshade aswell as in viewport. Is there anything I might be doing wrong ?
                            thanks
                            p.
                            Many Thanks
                            Patrick
                              You will need V-Ray RT SP1 for this to work; the original build does not have this command.
