I finally started using vrayRT GPU seriously now that it is installed and running on all my renderfarm nodes. So far so good.
The only problem is that the servers crash quite often with some scenes (ususally those not modeled inside max). In that case I have to restart vray RT server on each node. I do that remotely with LogMeIn Ignition But I'd like to automate the process and tell windows to restart vray RT server whenever it crashes. Is there an easy way to do that ?
Thank you.
Thank you.
