Annoying artifacts when using Adaptive dome + HDR or VraySky
  • Annoying artifacts when using Adaptive dome + HDR or VraySky
    Hello please see images attached for reference, as mentioned I have a dome light with adaptive set to ON and I get these weird lines across geometry on the scene, I tried BF+BF and also get artifacts but look different, similar to unfinished noisy small render buckets.
    Is this a known issue for GPU and is there a solution? Thanks
    Please send me the scene.
    Peter Matanov
    Chaos
      Did this get solved? I have the same problem at the moment... Really anyoing when rendering animations
        Most of the cases are solved. Can you send me a scene?
        Peter Matanov
        Chaos
          I have a scene where this problem still occurs, even after the latest update. Is Max 2017 and CPU, though.
            I can try to guess, but a scene will be most helpful.
            Peter Matanov
            Chaos
              I tried to archive the scene, but Maxzip errors out because of the size of the scene file. The packed zip reaches 2gb, then Maxzip gives me an error message. Any hints how I can get the file to you?
                If you have 3ds max 2019, try with it.
                Peter Matanov
                Chaos
                  I'm also getting artifacts with Adaptive dome and GPU in Max 2018.4 and Vray Next Update 1. Please check the screenshot below (contrast intentionally boosted for better clarity). If I turn off Adaptive dome it renders fine. Let me know if you need the scene.
                  Aleksandar Mitov
                  www.renarvisuals.com
                  office@renarvisuals.com
                  AMD Ryzen 9 9950X 16-core
                  96GB DDR5
                  GeForce RTX 3090 24GB + GPU Driver 566.14
                    Of course we need the scene
                    Peter Matanov
                    Chaos
                      Got it. You should now have an email with the download link.
                      Aleksandar Mitov
                      96GB DDR5
                        I just tested, and i can confirm that this bug(square artifacts) still exists on GPU(both progressive and bucket) in latest 4.1 . I reported this originally back in May, included the scene to reproduce it. Ticket 215-462-680. here is todays image to refresh your mind . I can see the logic in the adaptation patterns, but we don`t need to see it, lol.
                        Noemotion.net - www.noemotion.net
                        Peter Sanitra - www.psanitra.com
                        Noemotionhdrs.net - www.noemotionhdrs.net
                          Did you guys ever find a solution to this issue? This same issue appeared in one of my renders, but I wasn't using adaptive dome.
                          I was able to solve this by changing the light cache "Mode" to progressive path tracing (it was set to "fly-through"). After I switched this, the artifacts/noise disappeared.
                            What's your V-Ray version? There are presets for stills and animations.
                            Peter Matanov
                            Chaos
                            • #15
                              You should not be using the "Fly-through" mode and it is in fact hidden in newer versions of V-Ray. As Peter mentioned, it would be best to use the Still and Animation presets respectively.
