How do I correct my pixelated HDRI?
Pixelated HDRI
Pixelated HDRI
Bobby Parker
www.bobby-parker.com
e-mail: info@bobby-parker.com
phone: 2188206812
- 128gb Vengeance RGB Pro RAM
- NVIDIA GeForce RTX 4090 X2
- Windows 11 Pro
Tags: None
This is a feature that i've been asking for quite a while now.
The maximum HDRI size on V-R Dome ( v-ray GPU) is 8192 (memory efficient i guess).
Instead your CPU reads the full size of it.
So depending on your output size, it will be pixelated or not even if you take it up to 8192px.
Bear in mind V-Ray GPU doesn't affect how HDRI appears in reflections, in case you're willing to apply a backplate and cheat your background for high res outputs.Last edited by idnok; 16-02-2019, 01:12 PM.Regards,
Ledian
Yeah, that was my workaround, but for an animation, it won't work and this is for animation.Bobby Parker
phone: 2188206812
- Windows 11 Pro
I think raising it to 8192 did the trick, thank you!Bobby Parker
phone: 2188206812
- Windows 11 Pro
I have Update 1Bobby Parker
phone: 2188206812
- Windows 11 Pro
I don't know, 4k in an hour is pretty fast. This will eventually be an animation, so in post-production might be more of a challenge.Bobby Parker
phone: 2188206812
- Windows 11 Pro
Funny you said that. That's my usual workflow, but based on a previous post, I was told that was an odd way to light a scene.
Bobby Parker
phone: 2188206812
- Windows 11 Pro
Originally posted by vlado View PostWon't it work better to make the dome light invisible and set the HDRI as a background map as well?
VladoBobby Parker
phone: 2188206812
- Windows 11 Pro
Originally posted by glorybound View PostHDRI as background in MAX's environment or V-Ray's Environment override? I have always used MAX's environment slot.
In any case, we should do internally the same thing (we do it for the CPU anyways). I'll make a note about it.
- Likes 1
